00ek dx b16 swap 02 sensor
Discussion in 'Civic and del Sol - EG and EK' started by soapek, Jan 9, 2012.
  1. soapek
    soapek New Member
    so my problem is i have a dx and i dont know how many o2 sensors im suppose to run i have one before the cat and the cat that i am using has a hole for the o2 sensor but i dont see a plug . HELP PLEASE
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    Depending on what OBD engine you got + harness you could only have an engine harness supporting one O2 sensor insted of 2 which your DX harness orignaly used... just an idea there
  3. GmodKid
    GmodKid New Member
    Like serrilion mentioned. It depends if you're running a obd1 ecu which for that case u would only need 1 02 sensor but if your running obd2 which the car should be since its an ek you would need both 02 sensors. If you don't see one Hooke up to the sensor bong by the cat then I suggest you head to your nearest wrecker or junkyard and look for 2 sensors hunts in case u end up using both.
    Hope this helps
