00'gsr gears in 92' Ls tranny?
Discussion in 'General Tech and Maintenance' started by jginter, Jan 23, 2007.
  1. jginter
    jginter Junior Member
    iowa
    Iwas wondering if anyone knows if the gears out of a 2000 gsr tranny would work in a 92 ls cable tranny?
  2. 801CRX
    801CRX Got Rice?
    UTAH
    I belive they do.
  3. jginter
    iowa
    iwas also wondering what gear ratio to use. gsr 1st-4th and ls 5th or just all gsr
  4. 801CRX
    801CRX Got Rice?
    UTAH
    I would say 1st to 3rd GSR and 4th and 5th LS
    Only because the GSR is geared for acceleration so first through third would be ideal. For racing and that nice pick-up and go. And the LS fourth and fifth for cruising ideal for highway an freeway use. Cause you dont want to be topping out in fifth on the freeway.
    Good luck
  5. jginter
    iowa
    Thanks dude. im open for other opinions too please. i already had my ls trannsmission torn apart to replace the lower mainshaft bearing and now it is making some other weird noise from inside so out it comes again. the gsr tranny i have has a bad main shaft bearing also.
  6. jginter
    iowa
    Has anyone ever done this before?
