(01) H22A4 Engine into (96 ) Accord LX - ECU Concerns
urnemesis
Hi,
************H22A4 from Base Prelude 2001**********
  • Do you guys know if I can use the ECU on my 96 Accord LX? and if so what are the modifications I need to make given the ECU is Non VTEC and the donor engine is H22A4 (VTEC)?
  • Also the Automatic Transmission (Triptronic) has its own computer can I just use that computer with the Accord's ECU?
I been reading a lot and I am fully aware the computer on the Prelude since is a 2001 has the Immobilizer System that works with the (chiped) key and ignition system.
  • Will I be better off removing the whole ignition system and putting it into the accord?
Any help is greatly appreciated.:(
