02 civic
Discussion in 'Civic - EP, FA, FG' started by timv, Jan 25, 2009.
  1. timv
    timv New Member
    my headlights work in low but only left works on high beam swapped bulbs and the same thing happens daylight onl left works help?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    fuse
  3. timv
    timv New Member
    02 civic lights
    checked fuses , still the same when daytime lights are on there ios a buzzing noice... thanks tim
  4. AHHVTEC
    Alabama
    what about the headlight buzzer/relay gone bad. follow the sound down and replace that part
  5. timv
    timv New Member
    02 civic lights
    cool i will check it out tommorow thanks tim
  6. mnypaco
    mnypaco New Member
    under the steering wheel there is a grey box you need to pull that out and resolder the power connector inside the box
  7. timv
    timv New Member
    thanks will try
