Originally posted by R6Elmo@Sep 6 2003, 06:31 PM
you can't run the 02 sensors one after another in a downpipe like that. i assume you have an OBDII.
THe reason there are 2 o2 sensors is because one is normally before and one after the cat. Between them,they can extrapolate a difference. Since you have a downpipe, the difference is nothing. This will throw an error code in your ecu.
What you can do is buy an 02 sensor plug that you plug into i believe the second 02 sensor. This will give it some sort of reading so thte computer thinks there is a second 02 sensor.
I've seen these sell on ebay, summitracing and others. runs about 50 bucks.
