91_stylin_civic
Member
Not too sure if this is in the right spot. I have an 08 civic si coupe. I have a noise in the front end when turning the wheel at a stop or very low speeds. The noise sounds like the inner tie rods popping. Seems to happen more when its cold out. I have checked the front end every oil change and nothing seems loose. I called honda to see if there were any tsb or messeges for this concern( other then loosing the steering rack bushings and retorque which I tried). They told me no. The only thing I havent checked was the sway bar end links. I want to get the car on a drive on lift with someone inside to the rock the wheel. I havent had a chance to do this yet and the noise is driving me crazy. I just wanted to see if someone else has had this issue and could help me out. The car has 50,xxx miles on it.
Thanks
Thanks
