0bd2 engine harness to 0bd1 dash harness
maxcyclone21
dose any one know if a gsr obd2 engine harnes will work with a obd1 dash harness everthing plugs in but i didnt know if i would have problems with it runing or not i know i have to run a wire for the vtec but it a d series dash harness plz reply with some info
if you are tlaking about where the engine harness connects to the vehicle harness (at the shock towers) then you will be fine, just run those wires for vtec.
actually it won't work. the green plug right by the 3 ecu plugs doesn't match an obd1 vehicle.
