0bd2 to 0bd0
Discussion in 'Civic and del Sol - EG and EK' started by MoSeS, Oct 24, 2006.
  1. MoSeS
    MoSeS New Member
    how hard is it to switch a 0bd2 car to 0bd0? or can you make an 0bd0 engine to 0bd2??
  2. osnap
    osnap del slow? not for long.
    Atlanta
    neither is legal or reccomended. problems will come without a doubt; its better to just run the correct obd level for your car. what are you looking at, a B16 SiR?
  3. MoSeS
    MoSeS New Member
    nah im just getting desperate for an engine swap and obd0 engines seem to be a lot cheaper than obd2.
  4. ef8
    ef8 Junior Member
    Well then your best bet would be to just get the obd0 motor and convert it to obd2
  5. H-Ridah
    H-Ridah New Member
    Curaçao
    Damn man! That’s a hard one!
    I know of obd1 to obd2 and the other way around. Obd0 to obd1 is also no problem. Check out this site.
    http://www.boomslang.us
    They specialize in Conversion Harnesses. Maybe you can contact them and see if they can help you. Maybe you might even find what you’re looking for on their website. It would be easier to put a obd1 engine in your car. You can also try to google Honda Conversion Harnesses too and see what you can find.
    Good luck dude.
  6. trappd-in-859
    trappd-in-859 New Member
    burlington, ky
    osnap is right. Putting an older engine in a newer car is not only illegal, but way to much of a nightmare to even attempt unless you are a car genius in every aspect. Why not just get a d16y8 and do a junkyard turbo setup and make as much, if not more, hp and tq as a b series.
  7. civicguy88
    civicguy88 New Member
    if you really want to do this it is simple rywire.com has conversion harnesses so it makes it to where it is just plug n play
  8. trappd-in-859
    burlington, ky
    It is illegal to swap an older engine into a newer car, period.
  9. civicguy88
  10. ms.tuner
    ms.tuner Banned
    thank you officer.......dirka dirka
  11. trappd-in-859
    burlington, ky
    You can mock me all you want. I'm just telling him it's illegal. He can do the swap if he wants, but if his city has emission checks he's gonna be SOL.
    It's just a warning.
  12. MoSeS
    MoSeS New Member
    for starters no i don't have an emissions check, at all, in my state. i have been running with no cat for the past 2 years. second i already knew it was illegal, i don't care i just wanted to know if it was possible, but i think im just gonna find an obd1 engine and convert it, thanks anyways guys
  13. klungemonger
    klungemonger Junior Member
    Legalities aside, I don't know why you'd want to buy a motor that at best is 16 yrs old just to save a couple hundred bucks. There are supposedly some inferiorities in the head design also with the older ones. Plus those old swaps you need to change the injectors, they come with cable trannies, blah blah.
    IMO, it's the tranny that costs the most on the later swaps, and you'd have to get a hydro B16 tranny anyways so in the end you don't even save that much getting the old one. OBD1 is alright, easy to convert.
