1/4 times on your d-series
Discussion in 'Members' Lounge' started by racecarl, Sep 28, 2003.
  1. racecarl
    racecarl Member
    Stillwater, MN
    hey, i was just wondering what some of you have worked out of your d-series motors and what kind of 1/4 mile times you were able to put down. i want to build my d block a little but i want to see some results first.
  2. sohcslammer
    sohcslammer Senior Member
    Bay Area
    D16z6 in an EG coupe - Aem CAI, DC 4-1 header, DC Cat back, unknown high flow cat, unknown injectors, AEM cam gear, SI tranny, centerforce Dual-friction clutch, semi-gutted, DC short shifter, "Spoon chiped" ECU, 17" wheels = @ 15 flat. :woo:
  3. Liquidblaze
    Liquidblaze Senior Member
    Huntsville, AL USA
    D16Y7 98 CPE. Chikara Header, AEM Intake, no cat, Edelbrock 50-shot nitrous, yokohama avid H4 tires, AutoZone Clutch LOL. = 14.91
    I am also (this is what everyone tells me) a very good racer. 20% car 80% driver.
  4. Tonyd0821
    Tonyd0821 Banned
    96 y8 coupe. greddy 15g kit. stock exhuast, stock cat, no intercooler, stock suspension, stock rims/wheels, stock boost, no other mods whatsoever.
    ~15.00 flat.
  5. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    for a 50 shot and only running 15 flat? that doesnt mean ur a good driver at ALL, same with u tony. a boosted D running 15 flat's? ewww. i have a friend with a gutted eg with the d16z6, I/H/E and cam gears 13 lb flywheel and act clutch running a ZEX 55 shot and slicks.
    With Nitrous= 13.88
    Without Nitrous = 14.77
  6. Tonyd0821
    Tonyd0821 Banned
    first off my car is STOCK with the exception of the little snail blowing 5.5 psi into my engine. The ek coupe runs a 16.89 or some ridiculous number like that STOCK. so to get down about 2 seconds with minimal work....15's are just about right.
    my is STOCK. stock interior, no gutting, stock EVERYTHING.
    im sure if i gutted my shit, added my fmic, vafc hack, put on some REAL tires and rims (not my stock ones) and turned the boost up to 10psi, i could hit high 13's no problem.
    fact of the matter is, im in no hurry to get there any time soon, so im taking my time, saving up and most likely before the end of this year i will be high 13's. :D
  7. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    deja vu reading this page. weird ass.
    anyways, yea tony doesn't even have exhaust, so it can be expected his car is still slow.
  8. SleEPeR_CRX
    sry, i thought u at least had some work done, id like to see what the little D can get once u turn up the heat. theres a d16a6 Civic Si( 1991) with a 8psi turbo running 13.8 here, its sweet:) drops tranny's every other week tho:(
  9. Tonyd0821
    Tonyd0821 Banned
    ill get there. i just really do NOT want to put an exhaust on my car. i want it to look completely stock. this is so in the eventuality that i DO run someone...it will rub it in that much more that a "stock" civic owned their ass.
    im most likely going to get THIS weld on some piping and route the open end of the cut-out to a secondary aftermarket exhaust hidden under my bumper (not sure if it will fit, havent checked yet)
  10. noobvang
    noobvang Senior Member
    Twincities, MN
    Had a y7 in my 96 lx, did 16.3 w/:
    Gude TB, 4-1 header, clutchmasters stage 1 clutch and 8 lb flywheel, CAI, z6 tranny, and little other stuff.
    Slow but good for a 4dr.
  11. JrSiRb16A
    JrSiRb16A Senior Member
    Daytona Beach, FL
    not bad SOHC.. B)
  12. sohcslammer
    Bay Area
    You should see the NEW coupe.... Low 13s easy.... Just need a damn Hondata... :D
  13. TurboMirage
    ok time for some incredibly low numbers.
    92 civic hatch dx, stock, but recent tune up. 16.9.
    only the back seat removed, all season radials.
    now autocross, thats a different story.
