Possibly, I've had these for like a year and a half and this weekend is the 1st time I've put them on a car. They're about 18lbs a piece I've got some hankook r-comps on a decent set of konigs (11lbs) for autox.
Just swap the v6 into the rex. It would be like a faster version of the golf r32. With somethin like 320 horses at the crank already. That would be sick. Are the cl-s awd?
x2 on the rex (drool!), also wtf did the lady hit with that car? so weird to see the headlights unaffected.
rear-ended a new Accord the CRX has a browntop ZC in it....vac adv distributor and all (de-vac'd, removed charcoal and EGR canisters) also has a shitload of suspension upgrades, front and rear 1g teg brakes (rear disc)
its a track car the filters only on there because I had just de-vac'd the car when I took it the intake I had was an OEM with another tube routed over to the lower grill and the top half of another OEM air box mounted to the back of the grill as a pickup I have a (half built) turbo D16A1 that will hopefully be done/installed before the fall
You goin mini me with the d16a1? Check out the car on the front page of homemadeturbo.com. That guy runs mid 11's with a vitara setup in a a6 block with a y7 head I think. Stock block other than the vitara's, and head.
