At least the concept looks a hell of a lot better than those damn smart cars.
Plug that into the shop air at work for a quick refill.
fuck that, get a couple Viar 480 compressors (used on air bag suspension systems) and you will be all set...
Another expert expressed concern about the amount of energy it would take to generate the required air pressure: 4,500 pounds per square inch, or more than 120 times the pressure inside the tires of a typical four-door sedan.
"That is above what you normally find even in an industrial setting," said William Bulpitt, senior research engineer at the Georgia Institute of Technology's Strategic Energy Institute.
can vair 480's make 4500 psi?
