The 12v power supply outlet in the dash won't put out any power. I've checked the dash fuse and there isn't no fuses are burnt under the hood. Has anyone ever fixed this or know what might be wrong with it?
check the resistance of the lines coming into the compartment and also check the voltage with the power on.
you'll need a ohmeter and a voltmeter to do this.
