13s in a crx
rexskoo
what motor should i get . im lookin to get into the 13s all motor im my crx .
a lot will depend on the weight of the car with driver - to run 13.9 with 2300 lbs would take 200 flywheel hp - to run 13.9 with 1900 lbs would only take 165 flywheel hp - all of that is assuming you can get the power to the ground with the right gearing
B18C1 will get you there.
or a cheaper option you could always build up a b18a w b16a pistons and crower cams.
Get a type R transmission as well.
