14.6@105 WTF, need advise
Discussion in 'Integra' started by welfare, Jun 21, 2007.
  1. welfare
    welfare Ancient Member
    New York
    Went to the track for this first time since i put this thing together and am running consistant 14.6@ 103-105mph
    For those who don;t know
    1995 integra GSR sedan (yah, 4 door)
    Jackson supercharger
    10lb pully
    boost timng controller and vortec fmu
    walro fuel pump (I forget which one)
    AEM cold air and a 3" exhaust to a dumper
    The car is runing Great, A little rich, timing is set at stock + 1.5 degrees retard/lb boost
    Other than the HORRIBLE lack of traction I have, Can someone recommend anything to get my et down, I don't wanna go slicks, maybe drag radials, but what can I do as far as like a launch control or better than stock differential?
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    You've already got your problem pinpointed.
    P.S. Shouldnt a properly tuned B18c with 10 pounds of boost be laying down more than 205whp? Or am I crazy?
  3. SlushboxTeggy
    New Jersey
    That isn't that bad, my friend's Camaro use to run 14s at almost 120. It was crazy to watch him run.
  4. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    1.5 degree of retard/psi is a bit much. Do you have a EGT gauge? I bet that thing is tetering near 1600.......
    Traction is a must to getting good times, work on your launch!!
    And then there's the FMU.....OH dear..... Get a socketted ECU and do away with that boost timing device and the FMU, it will be money WELL spent :)
  5. phunky.buddha
    Dallas / Fort Worth, TX
    Yup, get your launch down and I'm sure you can run low 13s, maybe better. That trap speed is insanely high for a 14.6s car.
  6. formby
    formby learning in progress
    you need slicks and a good lsd
  7. welfare
    New York
    Yah, I just put the 10lb pully on on wednesday, right before I went to the track. I didnt update sig yet, thanks!
  8. welfare
    New York
    Im ordering some g force drag radials on monday, what do you guys suggest for lsd??
  9. phyregod
    phyregod !!YTINASNI
    Central Texas
    Everyone seems to like quaife. :shrug: never messed with lsd myself.
    You might look into getting a pair of motegi trak lites or konig heliums, or some kind of uber light weight rim for track use. Slap some slicks on 'em and tote them to the track in the back of the car, switch em when you get there.
  10. welfare
    New York
    I have steelies to put em on for now, but eventually, it all takes time.
  11. phunky.buddha
    Bottle, not stamp.
    If you want to go cheap, you can use the OBX LSD- just make sure you install it correctly! Quite a few people on Honda-Tech have had good results with it.
  12. formby
  13. welfare
    New York
    Thanks guys, Im def going to look into the obx, I'm not new to ripping soemthing apart and putting it back together, so I'm confident i can do the LSD without problems, Thanks all for the imput.
  14. eg6sir
    x2 on the LSD.... gonna look into it now.. :D .. it looks as if a monkey could do it
  15. welfare
    New York
    it's not really that hard to change the diff, I think the hardest part is to change the bearings over from your stock diff to the new one, I have had 3 or 4 b series tranny's apart, and it's really not that bad, just make sure you pay atenetion to what you take off that's all.
    As far as those bearings go, I have not ever tried to take them off the differential, and they may need to be pressed, all I know is that I have seen both beveled bearings and straight bearings in the trannys.
  16. b16GSR
    b16GSR B Series Guru
    go here and pick up a set of traction bars...did it to my GSR and im hookin up in a about .25 seconds with a set of Kuhmo Ecsta ASX tires
    Traction Bars Acura Integra
