14b
Discussion in 'Forced Induction' started by 97SIRTN, Jul 18, 2005.
  1. 97SIRTN
    97SIRTN Member
    So it looks like I can get a good deal on a 14b out of an eclipse.
    What kind of numbers should I expect?
    I plan on running 7-8psi, uberdata/whatever.
    This is for a daily driver, but it can't be too slow.
    Does this turbo spool quick?
    Will it hold the power to 8200 rpm's?
  2. jdm2gen03
    jdm2gen03 Senior Member
    yes it spools quik and it will run out of breath around 7 or so
  3. 97SIRTN
    97SIRTN Member
    Would you recomend this turbo for my b16 or not?
    Sound like no since it won't boost to 8200...right?
    I want to get around 250, would I just be wasting my time with this turbo?
  4. Speedracer228
    Speedracer228 ......
    waaay to small for a b16, get something bigger
    t3/t4, or go baller SC61, or homemade baller Holset Hx35 or Wh1c
    the 14b would have instant boost, and run out up top where theb16 makes its power, you wouldnt be happy with it at all
    check out www.homemadeturbo.com
