15 Or 16...is There A Difference?
integraracing91
Is there a big difference in speed between a 15" and a 16" of the same wheel? ;) (i.e. close to the same weight) and what are the best coilovers for a 94 integra ? :unsure:
go with 15's, with 205-50-15's.
and i'd go with ground controls/koni yellows.
setup will cost around 800, works very nicely together.
:werd:
depending on the width of the rims though id suggest 195/50/15's
you dont want a tire too wide for the rim or youll get "roll under"
best = Ohlins
be prepared to pay as much if not more than you payed for the car
you need to basicly find the right compromise of weight/rotational enertia/sidewall/outside diameter of the tire
-heavy rims are slower (in most cases)
-bigger rims take more power to spin (even if somewhat lighter)
-you need to have enough sidewall to absorb "issues" with the surface, absorb cornering force, but not too much sidewall though or you will get a spongey ride and a lot of "roll under" when cornering
-the OD of the tire relates directly to your gear ratio (larger OD you will acheive higher top speed but accelerate slower, smaller OD you will accelerate faster but top out at a lower speed)
there really is no set "perfect" choice... it all comes down to what do you want to do with the car
You couldn't fit any brakes under 6's :)
