150 Lb/ft In A B18?
Discussion in 'Engine Building' started by saturn_boy96, Jan 31, 2003.
  1. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    One of my goals with the Ls swap is to achieve from 150-160lb/ft of torque on the non-vtec head. Is it possible to do this while staying n/a?
  2. pissedoffsol
    cake.
    a little more revs, a larger cam, and some better flow, and you will hit it.
    stock is just under 130
  3. saturn_boy96
    Sheridan, WY
    should i bother upping compression. i plan to boost later.
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Higher compression helps a lot with torque. If you know you are staying NA, high compression pistons are a great investment.
  5. saturn_boy96
    Sheridan, WY
    if i decided to go strictly N/A and used some b16 pistons what kind of #s could i be looking at power wise? and with a vtec head?
  6. pissedoffsol
    ehh.. its hard to say. you can't just throw the vtec head on it... so its really how you build it is what its going to yield
    boost owns NA :)
  7. saturn_boy96
    Sheridan, WY
    yeah boost definately owns. but i plan on trying this thing out on the pro-solo circuit and i think if i can get around 220 whp with around 160 lb/ft ill own.
  8. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    b. he is talking about throwing b16 pistons in there not a VTEC head. I dont even know if they fit, but i am probally wrong with that. I would suggest looking at some non OEM pistons, something that has a high c-r, forged maybe.
  9. pissedoffsol
    ummm ok, maybe i'm bling or can't read or something...
    but to me, that clearly says vtec head
  10. lsvtec
    Really there is no way to know. Every build is different. I don't think that B16 pistons and a VTEC head swap would get you to 220 whp though. You would need some other work done.
  11. asmallsol
    Crap, i swear you edited that in there, i swear it just said b16 pistons.
