175hp@5200 205ft/lbs@4000
Discussion in 'Engine Building' started by thepester, Mar 16, 2003.
  1. thepester
    thepester Member
    How can I match 175HP@5200 and 205ft/lbs@4000? Thats comming from a Grand Am GT with ram air.
    Since my Civic is lighter, I figure if I have the same power hes got, ill beat him right?
    How can I get that out of a b18b or b18c motor?
    I dont ALWAYS need that much power, only when I race, I dont know if turbo works that way or not. Id like to be able to have to power when I race, and still be able to get the good gas mileage... build me up guys! I have 6000 to spend on the motor, i have to buy the engine with that money, and I dont want to pay more then needed. I only whay that much power. How can I do?
  2. mwasnp
    mwasnp Senior Member
    Hopkins, MN
    If you get some good deals and you do all the work yourself you MIGHT be able to get an ls/t into your car. Here is what I would do if I had $6k:
    Motor: $1500 or so
    ks motorsports kit: $3200 (comes with hondata)
    Tuning: $600 or so
    Rotas and Tires: $700 or so if you look around
    Run around 10 psi on a t3/t4 and you should be okay with good tuning. There are ls/t with stock internals that run up to 15 psi that are tuned properly and don't blow up. Proper air fuel ratio is KEY so you don't detonate at all, because if you do on stock internals you will throw a rod, blow a piston or ring, etc. That above though @ 10 psi could be good for 225whp 190ish tq. maybe more who knows.
  3. VtSol
    VtSol Junior Member
    6k, huh? You didn't say if you wanted those numbers all-motor. I'm gonna assume that you do. Typically, from the builds I've done, those are pretty reachable Hp numbers...torque not as easy for an all-motor B series. However, you won't need that much anyway.
    Option 1
    CrvTec- B20 block with internals, fully built- about $3500- That's professionally built.
    B16 head- about $500 Tranny $500 LSD- Varies $500
    Port and Polish, valve job- It varies but say between $800 and $1000
    Accesories- fuel pressure regulator,ecu...etc...Should be in the 6k vicinity.
    This should be an easy 210-220 Whp, 150-160 lbs. Tq.
    Option 2 B20 block- $800-$1000
    Pistons and Rods $900 Streetdriven cars run good on 10.5:1-11.5:1
    B16 Head- about $500
    Head prep- $800-$1000
    Tranny- $500
    ECU, engine accesories $1000
    Easy 195-200 Whp 140-150 Tq.
    Mind you, both these setups are reliable on the street as well as durable. Built right, you'll get what you want and more. All these prices vary, depending on your area. If you know a few people, you can get hooked for a lot less. You should be able to handle his ass with 200 Whp easy. If you add a 50 shot for aother $500, you can even give him room to toy with his ass. Happy racing, peace
  4. ek9r
    ek9r Senior Member
    Long Island NY
    B18C1/T3/T4 Turbo about 250whp @12psi
    or if you want to stay N/A pick up a B18C5 , its all you'll need. ;)
  5. thepester
    thepester Member
    are you saying if i put a b18c5 stock into my 94 civic ex coupe, it will beat a 2002 grand am gt w/ ram air?
  6. Baker
    Baker Senior Member
    Schaumburg, IL
    heres my brothers friends ls/t hatch the blue is before in tank fuel pump and the red is after. Hes just running LS with stock greddy kit and greddy intercooler
  7. mwasnp
    Hopkins, MN
    Shit thats a nice ass tq curve!!! 200ft/lbs @ 3500 rpm!!!
  8. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    well if your looking for torque at wheels, you can get taller gears. I think thats how the dc2 type-r does it, because it has a 4.7*** final drive while other cars have 4.4.
  9. pissedoffsol
    um - gearing doesn't effect toruqe in the least.
    in fact, go to a dyno - you will get the most accurate number at a 1:1 gear ratio, which is why most dynos are done in 4th gear.
    however, since it is closer geared, it SEEMS to have more power, but it doesn't- it simply keeps you in the power band better
