1965 Corvair mid V8
Discussion in 'Other Vehicle Discussions' started by ihatemyprelude, Apr 11, 2009.
  1. ihatemyprelude
    ihatemyprelude New Member
    Ocala, FL
    I bough this car about 7 months ago for 1000$ ( 65 Corvair V8 M/R) , it has a 350 with common bolt on and the stock trans, It drives and all that shit but the tranny insert shaft keeps braking cause the V8 is way to over powered. They say a 305 is the best with no major bolt on cause tranny issues. So i just gave up on it and let it sit, i dont want to make the car F/R so i was thinking, 3.8 National motor with low boost? My question is can i make this work, dose any one know any thing about this? thanks.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    sure if you can fab up some things it will work fine. a local guy here in my home town has one with a airplane motor in it, or is it a helicopter ? cant remember
  3. ihatemyprelude
    Ocala, FL
    mid or front engine? i seen some 3 cyl airplane motors but that has to be so loud in a car.
  4. AHHVTEC
    Alabama
    his was in the stock location in the back
  5. 97hatch
    97hatch ?
    Anderson IN
  6. cambruggeman
    cambruggeman Member
  7. 97hatch
    97hatch ?
    Anderson IN
    adapter plates suck and cause to many problems do you really want a spacer with long bolts holding your flywheel on i dont
  8. ihatemyprelude
    Ocala, FL
    ya adapter plates i never trusted and finding the right size bolts may create a problem, gonna have to go with the 305, or a 301 i seen in that 80s trans am thread.
    Or can convert the car to F/R and use a ford 9 rear fits up alight but thats last resort.
  9. 97hatch
    97hatch ?
    Anderson IN
    why not a 4.3l and boost that. All small block parts will work in a 4.3 and they are easy to find. and will bolt up you can also get carb intakes for them so you dont have to do the wiring for efi
  10. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    The CORVAIR motor does look like an airplane motor!! Thats funny. stick with the V-8 route. Corvair stock motor broke down all day long!! GM's weak attempt at a "for the people" car!!! VW did a much better job. Someone told me that the corvair was one of the big enspirations for the camaro....But....yes...wrong forum lol
  11. ihatemyprelude
    Ocala, FL
    ya 4.3 sounds the best and i dont have to deal with efi and all that, thanks for the help.
  12. newb
    newb phresh VIP
    Backwoods Northwest
    Sounds like you already got it sorted out, but +1 on the 4.3 swap. Theyre a dime a dozen, still mkae good power, but wont keep over powerin your tranny.
    Before anyone else thinks they should point out that this is the wrong forum, read the third tab in the header of the page.
  13. CAFROG
    NOR-CAL
    I see says the blind man....didn't know this forum had other vehicle discussions...sorry
  14. MthaFuknGreen
    Lodi, CA
    wasnt a corvair on that list of the one hundred worst cars of all time?
  15. sevenhillsbilly
    sevenhillsbilly New Member
    a 4.3 is a 305 with 2 cyl cut off is all it is i would def go with the 4.3
  16. ihatemyprelude
    Ocala, FL
    ya iam sure a good low end turbo on a 4.3 would give me plenty of power and a good weight ratio.. Never seen a 4.3 turbo corvair.. getting started on it some time next month. The car weighs around 2400 when iam done with it.
    The resulting vehicle weighed only 2,750 pounds with the V8 ( 350) (1250 kg), compared to 3,700 pounds (1680 kg) (1966) for a small block Corvette, and possessed independent rear suspension of almost the same design. Crown's prototype with 350 hp (261 kW) Corvette engine recorded an elapsed time of 12.22 seconds and 105mph
  17. joea
    joea New Member
    I know this is a year old thread, but do you still have this car? I am interested in getting one for myself.
  18. ricksautomotive
    ricksautomotive honda dealer tech
    lancaster, ca
    i think you are correct that the corvair was the inspiration for the camaro. i dont know how many people have seen my neighbors sittinin the yard in deconstrution for the last 4 years and have mistaken it for one sweet camaro gettin restored. i have to tell em to look again and that its a corvair. the body lines of the corvair do resemble 67-68 camaro lines. maybe even 69s too
  19. ricksautomotive
    lancaster, ca
    yes the corvair was said by many groups to be one of the worst cars of all time. but few even know that the corvair was one of the first Yenko cars and that few were ever made...making a yenko corvair one of the sweetest rare cars to ever get for a yenko collector. but in my opinion, yenko or not, its still a corvair and on of the worst cars ever
  20. skymangs
    skymangs New Member
    Funny, my vote for worst car ever goes to Honda.:ph34r:
    My Crown conversion with a 68 Camaro 302 (converted to roller) never breaks. The 302 keeps the torque off the bottom end, but revs over 9000rpm. Makes peak torque at around 5500rpm. It'll put the smack down on a lot of unsuspecting victims.
    ~Skyman
