1979 Honda 5 Speed 3 Door Hatch
Discussion in 'Accord' started by CiPhEr, Jun 3, 2009.
  1. CiPhEr
    CiPhEr New Member
    City of Lost Angeles
    Ok check it before you hound dogs rip me apart I have read many fourms that say to keep it stock. IF I COULD I WOULD, but due to the limited amount of 1st gens in the pick a part and special order this special order that i dont have the time nor patience.
    With that said. I have a 79 5 speed. Due to excessive oil consumption (sliped main berring) and 2 ruined heads on cylinder 3 I have decided to remove the CVCC that is in it and put a D15b7 from a 95 civic OBD 1. My question to you guys is has anyone swaped a D series into a 79. :confused: Im not inturested in B series only D series.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    it can be done but it will be 100% custom job.
  3. Hondadude141
    TX
    Good luck with that, I hope you know how to weld.
  4. CiPhEr
    CiPhEr New Member
    Welding's not the problem. Whoever worked on the car b4 i got it decided they would make the air conditioner switch the coolant switch as well. so I always have to have the air going to cool the engine down.
    If anyone knows the electrical on the car would help a ton and what harness i would need to make this work. I have a P72 ECU
  5. AHHVTEC
    Alabama
    well if the car was carbed then just use the wiring harness for the motor you pic.
  6. eduardo i.
    eduardo i. New Member
    Carolina, PuertoRico
    1stgencivic.com has alot of info and a good forum, oost here too to see updates:)
  7. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    no,but that is a great concept cant wait till you get done and show some pics as the motor goes ive done alot of d series motor swaps and use the d15b7 harness and wire driverside into dash shouldnt have aproblem with axles becuz the axles should work in your 79 civic,idid a 81 civic with a d16y8 vtec and there basically the same procedure so good luck
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    Truthfully, if you can't fix that problem yourself you'll never get a D series running in it. Its doable, but you really need to have a good amount of knowlege to tap into.
  9. eduardo i.
    Nope, axles dont work on firstgencivics but they do on secondgens. Youll need secondgen hubs,axles and an 88-91 tranny( because itrs the only d that was cable, the integra86-89 works too)Youll need a firstgen wagon caliperbrakets so you can attach 88-91 or newer calipers and rotor. Youll need to throw new fuellines to the tank and also a new pump.There are someother thinngs you need to take into consideration, again, check 1stgencivic( or 1stgenhonda also, its the same site) Itll be of great help ^_^ Keep us posted here:)
  10. eduardo i.
    Oh and Cipher, 1stgenhonda also covers accords, n600, secondgencivics, but remember to keep posting here so people see our old civics:D
  11. eduardo i.
    Wow just realized, it was an accord,so I guess you wont need the caliper brakets and the hubpart will be a little different.
