1985 CRX Carb leaks
Discussion in 'Civic and CRX - EW' started by MoscoCRX, Oct 5, 2014.
  1. MoscoCRX
    MoscoCRX New Member
    Hello Folks,
    Perhaps you fine people here can lend a hand with this situation.
    I recently pick my self up an 85 CRX, It needs some TLC but otherwise in great condition.
    When I went to turn it over and see if it had any major issues, no starts, seized etc.
    The Car cranks but it will not turn over, Carb shoots clouds of gas from it, and squirts gas out from the Accelerator Pump section. I turned the car off immediately, because my engine compartment was soaked in gas.
    I took the Carb off and apart and noticed it was missing a few things. For starters the carb had no gaskets at all [​IMG]
    Also found the gas leaking from the Accelerator Pump assembly.
    The Accelerator pump lever Pin is missing something ...
    I have been looking all over for a replacement for this Carb everywhere, havent been able to find one that looks like mine, the ones I have seen all have electric chokes, not manuals.
    Also its canadian, I was told this looks different then the american ones ?
