1988 2.0S Swap Possibilities
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Prelude88, Feb 3, 2005.
  1. Prelude88
    Prelude88 Junior Member
    Fraser Valley, British Columbia
    Hey all!
    Finally able to find a decent site about Honda engine swaps.
    I'm new to this, and I'm actually taking apprentice courses for mechanics as of Monday, so bear with me as I'm sure I'll be a noobie for the first little while here.
    My ride = 1988 Honda Prelude 2.0S
    Carburated Engine (blah)
    My question:
    What is the best possible engine swap for this model? (JDM?)
    Are there JDM motors that can be swapped directly into this Chassis without any fabrication?
    Also, because it is a carburated engine, will I need a new Ignition, radiator, dash and steering column?
    I know, noob questions, but every little bit helps, and on Monday I'll be well on my way to know how to do this.
    Thanks for any help
    :worthy:
  2. Prelude88
    Oh, and btw.
    The current engine in the Prelude is a B20A3.
  3. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    First off you don't need to swap some of those components. Search for a DPFI to MPFI conversion this has been covered many times. This is the first step needs in ANY swap you do. I don't not believe there are any direct bolt in swaps; you will need to purchase a motor mount kit, afterwards would could swap just about any engine your Honda heart desires.
  4. Prelude88
    Ok, so is this conversion a OBD0 ----> OBD1?
    I just saw something about these on the forums, and I'll read into that, but I'll need something like this:
    http://www.jkobdconversionharness.com/0to1.htm
    To at least cover the wiring conversion?
  5. Prelude88
    Alright.
    So I think I have this right, please correct me if I'm wrong.
    My prelude, being a third Gen, is an OBD0.
    To convert it to say an H22A motor, I would need a Mounting kit to mount the motor and a wiring harness to be able to connect the OBD1 engine to my OBD0 Prelude?
  6. Prelude88
    Ok, so after further researching this on the forums here, I found a chart listing all the Honda Engine codes.
    Because my Prelude is an 1988, it is a OBD0 Engine.
    The B16A (SiR) according to that engine chart is also a OBD0 Engine. I'm assuming that swapping this motor in would be significantly easier than doing say an H22A.
    So, assuming I choose to go with the B16A engine, what am I going to need to do this swap?
    http://www.jdmsource.ca/honda/b16a1.html
    Engine
    Transmission
    ECU
    Alternator
    Air Conditioning
    Power Steering Pump
    Distributor
    Wiring Harness
    That is what is included with the purchase of the motor, is this all I need for the swap?
    Again, I have a 1988 Honda Prelude 2.0S
    Thanks for your input
  7. projectxspeed
    New Hampshire
    I am not very knowledge in 1988 Prelude, but what I can tell you is this:
    - This is the only (best) site to use to get engines from, call them
    - Your car is indeed obd0 that doesn't mean you have to keep it that way.
    - There is a lot of wiring involved with your car.
    - Even an obd0 b16 requires the dpfi to mpfi conversion (tons of wiring)
    You are learning keep up the good work :thumbsup:
  8. Prelude88
    Gotcha. Thanks for your help. Starting to pick on some stuff, this site is great.
    Thanks again for the help.
  9. Dustin_m
    Dustin_m Active Member
    San Diego, CA
    Hmm, he jsut said that its carbeurated. carbuerated cars present a few more steps to a swap. first off you will need a new gas tank. that is, unless you want to swap in a newer B series and keep it carbed. but yea the FI systems ae pressurized, and Carbed fuel systems aren't. I did a quick search and this is a thread that showed up kind of like yours.
    click here
  10. projectxspeed
    New Hampshire
    Here is another great link for a write on carb to fuel injection.
    Walkthrough
  11. driverunknown
    driverunknown Senior Member
    Dude just stop posting.
    that shit is dpfi to mpfi...
    Do you even know what that means?
    Dual
    Point
    Fuel
    Injection
    Multi
    Point
    Fuel
    Injection
    Notice how both of those systems say fuel injection?
    Dual point does not mean carb.
    BUmp for the main poster.
  12. Dustin_m
    San Diego, CA
    :werd: :whatafucktard:
  13. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    you'll need to convert the fuel system to handle fuel injection- then you'll have to tackle wiring- IMO swapping a b16 in would be retarded and i'm not sure there are even mount kits for b series into the prelude. You're best route of action would probably be to swap in a B20A5 or B21 from the same year preludes- You get fuel injection and some companies actually make parts for these motors- If you look you'll be able to find pistons, rods and there used to be turbo setups for the car, although from what I know he isn't making them anymore- But that doesn't mean you can't make you're own custom setup and make gobs more power than you would make on an other b series swap-
    also, when swapping anything other than the b motors from those generation preludes you'll fight mount issues, possible cable to solid linkage shifter conversion (if swapping to any other B series motor)
  14. phunky.buddha
    Dallas / Fort Worth, TX
    I was wondering about that.... because as far as I know, there was never a DPFI B series engine. I don't know much about the old Preludes though (plus I missed the carburetion comment), so I just kept my mouth shut. I don't like to spew misinformation when I'm not sure about something. Maybe you should do the same.
  15. Prelude88
    Hey all.
    Thanks for the bump, I've been busy working on the body stuff and just got a chance to come back and see what else is here.
    So from what I see, maybe trying this whole JDM thing might be a bad idea?
    Maybe just use this as a car to learn from and maybe try and find another prelude that came as fuel injected?
    I really wouldn't mind at all. I love my car now, and would love to use this, but as a starter, maybe just use it as a stepping stool and go from there with a newer lude?
