1989 Civic Dx 1.5
Discussion in 'Engine Building' started by WNT2LOSE, Jan 15, 2003.
  1. WNT2LOSE
    WNT2LOSE Junior Member
    I have an 89 civic dx with a 1.5 what would be good to upgrade the power and performance. i would like to make it into a lil racer but i just got into the the lil rice burners so i don't know much bout them
  2. ZAC
    ZAC Member
    An engine swap,I've got a 90 civic hatch. I'm going with a b16
    or ls/vtech
  3. VTECcivicVTEC
    VTECcivicVTEC Banned
    i got SOHC VTEC motors.... trying to get rid of em, easy swap...bolts right in.
  4. WNT2LOSE
    what type of engine would bolt right into usong my tranny and wiring and ecu?
  5. red95solsi
    red95solsi Senior Member
    Kansas City Missouri
    any d series would bolt right in without having to get new mounts a zc engine is cheap and good power for the amount it costs
  6. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    not much check out the ZC for most swaps you will have to do the MPFI swap, which is not that hard... crxpower.com has an excellent guide on how to do it, it is in the forums under how to... with the zc you can use you stock mounts, but the DX tranny has a weak final gear, i would recomend putting an 88-91 si final gear in your tranny or getting an 88-91 si tranny for the swap. you will have to change your ecu for most swaps, but it is not that big of a deal to do.
    Good Luck and if you have any questions PM me i have an 89DX and i am in the process of an MPFI swap.
  7. knowledge
    knowledge Senior Member
    Beale AFB, CA
