i got a 1989 civic dx i got a b16 just the motor and ecu with parcial wireharness and i got motor mounts what else do i need to put this killer vtec in my car????
axles, shift linkage, exhaust, intake, integra throttle cable, integra radiator hoses, and i would recomend a complete tune up, including water pump and timing belt.
You need to convert from DPFI to MPFI. Either wire it up yourself or get an Civic/CRX SI, CRX HF harness, or conversion harness from hasport. You cant use the harness that comes with the engine! That + everything ^^^^^^ said and spark pugs/wires, new clutch, and a timing belt tensioner.
