1990 B18a1 block
Discussion in 'HYBRID -> EG-EK / DC' started by Honda18, May 24, 2005.
  1. Honda18
    Honda18 Junior Member
    Ok I bought a complete swap (97 B18b1) I was going to put in my car(97 civic hx)
    OK well I got a deal on this dart sleeved block(1990 B18a1) I want to use this block for the swap I also have piston and crank.
    Well the A1 has a hole on the back on the bottom right side of the block, I was told it was for a breather chamber.
    The 97 B18b1 has no such hole in the block.
    My question is Can I still use the b1 head and intake manifold with the a1 block do I need this breather chamber or can I just seal off the hole and not use one?
  2. Saa96civicEx
    Saa96civicEx New Member
    I also. Need info on this
  3. Saa96civicEx
    N yes I know it's from 10 years ago
  4. Briansol
    That was for the old pcv system. you can simply run a hose form the IM to the valve cover directly and figure out a way to block the hole up.
