1990 b20 civic si wont start :(
Discussion in 'General Tech and Maintenance' started by 89vwfox, Jan 27, 2009.
  1. 89vwfox
    89vwfox New Member
    i was out driving last night and out of no where my car sputters for about 3 seconds and my engine light flashes a couple of times and then my car dies. I pull over on the side of the road and try cranking it again.......nothing and my fuel pump isnt turning on.. I check my fuses under my hood there are 2 blown my ecu and another one. i proceed to check my underdash and there are 2 blown there also. i replace them and still no fuel pump. When i got home i opened up the fuel tank access panel under my back seat. i checked for voltage on the 4 wire plug that gives power to my fuel pump and fuel gauge/float inside the tank. On the float side i got a healty 12.8V but on the fuel pump side i got a big fat goose egg..I'm thinking it could be my fuel pump relay but not sure. I already have a new walbro 190lph fuel pump on the way. The one im using now is the stock pump from 1990.
    Any ideas what it could be?
  2. Travisl
    Travisl New Member
    wichita,ks
    it might be ur main relay and r u from wichita
  3. 89vwfox
    89vwfox New Member
    na from texas....created my own power source and the fuel pump turned on.....so is it a relay?
  4. Travisl
    Travisl New Member
    wichita,ks
    might i had the same prob i changed the relay and it worked fine tll my dizzy shit hte bed
  5. 89vwfox
    89vwfox New Member
    bought a new relay didnt do any thing...checked my grounds they were all good... and i keep blowing my 15a ecu fuse each time i turned they key into the on position. when i try to crank the car i can hear my fuel pump .
