1990 Civic Si fuel pump relay?
90SiZC
Does anyone know what other models/years used the same relay? As in, exactly the same? Something I don't have to rewire/wire around/replace connectors to make work?
The one in my '90 Si is starting to be intermittent.. sometimes a gently tap (small hammer) is enough to get it to kick on again.
TIA
Jim
Dallas
1990 Civic Si, JDM ZC powered.
are u talking about the pgm-fi relay (which has the fuel pump hooked up to it) located under the left side of the dash not with the fuse block? if its that one then yes there are 2 different pgm-fi relays for that generation.
