Hasid Lafre
Master of the obvious
Ok your temp guage just raises and such and it dosent run right or it seems to run right.
Now this happened on my friends DX a while back, We found out that there is a plug on the back of the block that wasent connected to the rest of the harness. I pluged it in and everything ran fine for a while. Then it turned out to be a bad injector. We checked it using other injectors but they turned out to be bad also. So out of the win we went to the J/Y and pulled an injector froma random DX. clipted it and pluged it in and fired it up and it works just fine. The only thing wrong with it now is the trans is ded.
