1990 hatch wiring
razma369600
hey guys i have started my swap and well what do i do about the wiring? I am running a a6 block z6 head and the 90 si tranny some of the problems i see is that the wiring is set up for DPFI and the z6 is well MPFI how do i get around this? Also i have bought a 92-95 si ECU
You will need to convert your car to MPFI first. Then if you want to run the P28 ecu, you will need an OBD0-1 conversion harness. I can rewire your engine harness and make the 0-1 harness if needed. Either way, let me know if I can help out.
Jason
