1990 Ls into my 1991 crx hf
Discussion in 'ECU's, Electronics, and Tuning' started by ExclusiveImports, Oct 4, 2006.
  1. ExclusiveImports
    ExclusiveImports Junior Member
    everything is great did my wire harness from scratch car turns on just wont rev past 3000 rpm gives me code 4 ckp sensor what can i do to fix this?
  2. pissedoffsol
    crank position is in the dist. wiring. check the wiring
  3. ExclusiveImports
    wiring was redone and it was working fine now i got this code and it wont rev past 3000 rpm it did before but now it wont so it cant be the wirig!
  4. EG93sir
    EG93sir Racer X 904
    jacksonville fl
    try a known good distributor,or possible ecu mismatch
