1991 Accord Ex Swap?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by hrricane34, Mar 3, 2003.
  1. hrricane34
    hrricane34 Junior Member
    I have a 1991 Accord EX and would like to swap the engine. What motors will fit into my Accord with no modifications to the engine mounts and without changing the tranny? Also, what about the ECU and wiring harness?
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    The H22 will swap in there, but I wouldn't recommend using your F22 tranny. You'll have to get a new ECU, and you'll have to convert from OBD0 to OBD1.
    Check out http://www.h22a.org for some more info.
  3. hrricane34
    You mentioned that the H22 will fit, but will it be a direct fit withoug messing with engine mounts and header/exhaust? Are there any other precautions that I should be aware about?
  4. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    if you want to do a swap, dont be cheap about it... do it right, or dont do it at all.
