superman1000
I just recently had a clutch and pressure plate put in my 1991 accord. I have noticed lately that about third gear it pulls to the right a little and it sway back left when i get off the gas and streighten up no virration rides smooth. It also pulss to the right when i hit the brakes. This morning it was making a poping noise when i hit the brake like something was loose when you take it pop like it went back in place. Taking off it does not do it only on braking. If i hit the brakes going backward there is not noise onwhen i go forward. I am thinking that the sway bar might be loose at the front by the cross member. I did find a few bolts loose when i got under it the first time i am going under today to see if there are any more loose and idea guys what it might be?
