1991 Auto Accord - Starter Replacement
Discussion in 'General Tech and Maintenance' started by wanderinman, Oct 21, 2005.
  1. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    My girlfriends starter went out on her automatic accord. I figured I can replace it for it, I've done starters on other cars, was just seeing if there was anything I should keep an eye out for on hers.
  2. formby
    formby learning in progress
    nope
  3. hatchback
    hatchback Member
    Disconnect the battery, then:
    1. Unplug/unbolt the wiring.
    2. Yank the two bolts.
    3. Pull out starter.
    4. Reverse opperation for install
    Just like just about every other starter on the planet.
  4. reckedracing
    reckedracing TTIWWOP VIP
    NY
    you sure its a starter?
    check grounds, make sure the starter bolts are tight, remove starter and check flywheel teeth, just standard stuff
