1991 civic std gsr swap harness
Discussion in 'Civic and CRX - EF' started by Drewpro, Dec 1, 2017.
  1. Drewpro
    Drewpro New Member
    I'm currently working on swapping a obd1 converted b18c1 into my 91 std hatch, I noticed that part of my harness to the injectors is missing, what other harness with work in my car?the other parts that are there are chopped up at the ecu connections.also if I'll be using a obd1 p28 ecu what needs done to the injector part?
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    You need a dpfi to mpfi conversion harness
  3. Drewpro
    Drewpro New Member
    Ok I understand that. But with the ecu interchangability what other harness would fit and be correct
  4. dilbeckskate
    Kennesaw Ga
    do what ? you would do a dpfi to mpfi conversion harness and a obd0 to obd1 jumper harness at the ecu and use a p72 or flashed p28
  5. dilbeckskate
    Kennesaw Ga
