1991 EX Sedan not charging.
Discussion in 'Civic and CRX - EF' started by civicxxman, Apr 21, 2009.
  1. civicxxman
    civicxxman Junior Member
    I came across a 1991 ex sedan that is for sale and the problem is the battery is not charging. I figgured I could test the wire that activated the alternator and make sure that the wire that runs to the battery is good and possibly drive the car home with less than an hours work. I also thought the car might have a bad ground and the alternator is brand new.
    Can any one think of another reason why the car would not be charging?:ph34r: oh buy the way this car is a whopping 750 obo so its probably going to be a $500.00 car.
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    could have a blown 60 amp fuse in the main fuse box - the one on the far left closest to the battery
  3. civicxxman
    so it would still run with out that fuse? cool i will check it out.
