1991 hb swap
Discussion in 'HYBRID -> EG-EK / DC' started by kenny, Nov 10, 2002.
  1. kenny
    kenny Junior Member
    i am about to but a 1991 civic hb. i have a b18a1 out of a 1991 integra. will it go in with out place raving motor mounts. the front and the two sides look like they will fit but the back mount doesn't if you know any web pages that show this install please let me know :)
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    you will need all new mounts, you can get them from a variety of different places...i.e. placeracing.com, hasport.com, hcpengineering.com, you will also need shift linkage, axels, and maybe a wire harness i do not know about that one. don't over look thing like radiator hoses too.
    Good luck.
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    I think you will need a wiring harness because the 91 Civic engine is DPFI and the B18A is MPFI.
  4. Jeef
    Jeef NO MA'AM Moderator VIP
    Try to get as much of the harness as possible if you can for extra plugs. Make sure you get the injector resistor box and fuel injector plugs.
