1991 Honda Accord Auto tranny problem
Discussion in 'Accord' started by LtWilliamT, Sep 8, 2011.
  1. LtWilliamT
    LtWilliamT New Member
    Akron Ohio
    I have a 91 accord DX with auto tranny. The reverse gear blew out, so i did a tranny swap with the same type (with low milage). When i got done, i went to drive it and it wont stay in gear. It would drive fine for awhile, then it just wouldnt go anywhere. I did 3-4 fluid flushes (magnit had a few shavings, but nothing bad) Still does the same thing. Idk what it goin on, maybe the shift solinoids? any info would help.
    Note: "S" light goes on and off as it should, so i dont think its the TCU.
    Please help!
    Thanks Will.
  2. darkknightness
    darkknightness New Member
    I would open up the TCU to check and see if you have this . Ive had problems like this before . If it is bad just get a replacement from the junkyard
    [​IMG][​IMG]
