BlueballSiR
Member
FOR SALE:
Lower half of the motor was put together by fast times in morton grove, il. srp forged 30 over fly cut pistons. 8.5:1 compression. world product windsor jr alumn heads, ported and polished by fast times. edelbrock performer rpm intake. accufab 70mm throttle body. pro-m 77mm mas air. comp cam. arp stud mounted. comp 1.6 roller rockers. trick flow hardened pushrods. shorty headers. off road hpipe. 2 chamber flo's w/ dumps. centerforce duel friction clutch. FMS adjustable clutch quad. pretty fresh t5. pro5.0 short shifter. 373 gears. 255 fuel pump. 30# injectors. subframe connectors. bbk springs. battery in the trunk. no a/c. lots of new parts like battery, starter, alternator, 180degree thermostat, 3 core radiator, power steering pump. Its white with grey leather interior. car also has the pony rims. car runs perfect, doesnt leak or burn oil. motor has about 20k miles on it and the odometer reads almost 110k miles. paint job is about 3 years old. Asking $5000. Will trade for 1992-up Hatchback stock + cash. Located in Glenview, IL
