1992 dx swap
Discussion in 'Civic and del Sol - EG and EK' started by vickin, May 30, 2008.
  1. vickin
    vickin New Member
    well im new to hondas. I mostly have a dsm and srt4 background. i have been looking around on here for swap info. I have a 92 civic dx with a d15b7 in it.
    Im just looking for more power. I know the car is obd1. so i was looking at the b16a2. is that a direct swap, if i get the motor, ecu, trans, etc...
    thanks a ton
    Andrew
  2. BrutalB83
    Rochester Hills, MI
    The B16A2 is an OBD2 engine. It's not a difficult swap; you either need to convert the engine to OBD1 or convert the car to OBD2 (converting the engine is probably the best option assuming you don't have to deal with inspections), but not quite a "drop it in, bolt it up, and plug it in" type of deal...
  3. vickin
    vickin New Member
  4. |Chaz|
    |Chaz| Well-Known Member VIP
    Is it a hatch, coupe, or sedan? Pics?
  5. vickin
    vickin New Member
    its a sedan. basically what im looking for is to buy a b16 for less then $2000 and swap it. is it possible for everything to plug right into each other, or do you have to hack your harness?
  6. vickin
    vickin New Member
    its a sedan 5spd. i cant post pictures. i have to wait for admin approval?
  7. vickin
    vickin New Member
  8. reikoshea
    Dallas, TX
    sorry about the wait on the pictures...it takes a little while to get to this stuff on fridays and saturdays (most of us go out those nights).
  9. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    The b16a2 isn't just an obd2 engine, its obd1 as well. 1992-1995 civic si-r engines are b16a2 stamped, but they are also JDM engines, and are obd1. The usdm b16a2 (99-00 civic si), is obd2b.
  10. vickin
    vickin New Member
    to post 8:
    im working so its all good.
  11. BrutalB83
    Rochester Hills, MI
    Really? I thought all JDM engines only had 4 digit ID codes...
  12. LS_VTEC
    NJ
    You thought wrong. :)
  13. BrutalB83
    Rochester Hills, MI
  14. BrutalB83
    Rochester Hills, MI
    So is that a pretty rare thing, or are there lots more JDM engines with 5 digit ID codes?
  15. LS_VTEC
    NJ
    I may be wrong here... B16a2 (92-95 si-r) is also the Canadian model, but may also be JDM as well.
  16. |Chaz|
    Ooooh it's my car.
    Here OP check out my fodo
  17. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Damn you and your sexy car, Chaz! It strikes again and I couldn't rep you for it! Damn the rep God's for now allowing multiple reppage!!! :wallbash::disgust1::sniper::rant:
    By the way Vickin, I would suggest converting the engine to OBD1. The reason? It is MUCH easier to tune OBD1 than it is OBD2. That's just my own two cents from what I have learned. Check out Rywire - Online Store for any harnesses you may need. Also, search around the site and you will see how others have gone about doing their swaps. :D
    You will need new motor mounts for sure. Best of luck on your swap. :thumbsup:
