1992 Integra B18C5 Swap
Discussion in 'Integra' started by cparker, Sep 10, 2007.
  1. cparker
    cparker New Member
    I have got a 1992 Integra and am looking to swap in a B18C5 engine. This is my first FWD swap. I came from the drift world. This car dropped into my lap. I need to know if I need a engine mount kit or any special kits to finish the swap. Any feed back would be awsome.
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    The integra originally came with a b series engine. So if you use all the mounts and brackets that came with the car you wont need any other mounts. If you are running the new hydralic transmission you will need the hydralic to cable conversion kit. I believe you can get it from Hasport Performance, Inc. or Welcome to Innovative Mounts Most of your work will be in the wiring. I recommend staying obd1 and getting a p28 ecu chipped with a type r base map. To convert over to obd1 on that engine you will need obd1 vtec injectors, dizzy, and alternator.
  3. cparker
    cparker New Member
    Do you think the Type R is the way to go or do you have any other suggestions?
  4. Matts96HB
    Matts96HB . Moderator VIP
    LS/VTEC is always a good way to go. If you still have your stock motor you can use that bottom end and a b16 or b18 VTEC head. Its cheaper and with the right parts and tuning you will make just as much power as a b18c5 or jdm b18c
  5. cparker
    cparker New Member
    I don't have the vtec block though does that matter?
  6. cparker
    cparker New Member
    What parts are we talking about. Are we talking rods and rings, cams, valve kits, ecu? I have no clue when it comes to these cars. Thanks for all the help.
  7. cparker
    cparker New Member
    Now here is just a curiosity question. Is there a way to get my brothers K20A Type R engine to fit? Cause he has got one sittin in the garage.
  8. BrutalB83
    Rochester Hills, MI
    And why is this posted in the "auto multi media" section???
    This forum is for people to post pictures of their cars, not ask technical questions...
  9. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    moderator: move this thread.
    yes you can put your bro's K20A in your teg. Hasport Performance, Inc. should make mounts. looks like you might have to call, but they should do it. they are avalible for 94-01 tegs...
    kind of pricey, but worth it if you dont want to try and make them yourself. some custom wiring will need to be done. is a shop doing the swap, or basicly you?
    K20 would be sweet in a teg. keep us updated!
