1992 Integra LS Engine Swap
Discussion in 'HYBRID -> EG-EK / DC' started by TrueStifmeister, Oct 4, 2002.
  1. h22a into 1992 Integra LS
    100.0%
  2. Different Engine (need a decent cheap o
    0 vote(s)
    0.0%
  1. TrueStifmeister
    TrueStifmeister Junior Member
    B-more
    Any suggestions as to another engine?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Boosted LS or Boosted B20. If you want to run NA, B18C1. The H22 is not going to be cheap or as easy, but you would have much more torque over a B series. If you plan on AutoX then the H is probably not the best choice, but if this is a straight line racer the H has the most torque from your list. If you still have the LS bottom end then an LSVTEC is a good option.
    I guess what the question comes down to is what (if any) kind of racing do you want to do?
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
  4. pissedoffsol
  5. LSvinny
    LSvinny Junior Member
    dam right, boost the ls i`m building a b18a1 and there talking 400hp by the time i`m done with it at 15 to 20 psi and a little bit of money
