1994 eg8 civic no spark
Discussion in 'Civic and del Sol - EG and EK' started by muffin boy, Mar 31, 2008.
  1. muffin boy
    muffin boy New Member
    Hi Guys,
    i did an oil change on my civic last night, i flushed it with a mixture of oil and diesel. i started the engine and it ran for 10 seconds then stopped. i have since removed all of excess flush changed the filters and refilled the oil. Now i have no spark since it stopped during the flush. I have oil pressure, and i have compression but no spark, i took the dizzy cap off and checked the rotor is still spinning which it is, all the fuses and relays seem to be fine, fuel pump fires up, i hear the main relay click when i turn the key, any ideas?
  2. Mugen Accord
    Mugen Accord West West Y'all
    Downey, Ca/ Lancaster, Ca/ Alice, Tx
    Double Check Tha Spark Plugs and Wires.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  4. muffin boy
    How do i check to see if i have power to the dizzy?
  5. OKCZombie
    OKCZombie Banned
    I personally have never tested a dizzy itself - I always check to see if it is putting spark through wires - get a long screw driver put it in one of the wires and put the screw driver near something metal such as the frame and have somebody try to start it - start w/ number 1 cylinder and move through -
    you could also open the dizzy and check to be sure all of the contacts are good - no corrosion or anything
  6. matt9112
    matt9112 New Member
    i had a bad cap on mine and shop changed it and new wires ect for 70 bucks.
