1994 LS into EG hatch problems
Wokam
So I've got the motor mounted in and the wiring harness (from a B16 that was already in the car) partially hooked-up. My water temperature sensor is broken so I'll have solder up a new one on there. I also have some plugs that have no where to plug into or I dont know where they go. Such as IAT, VSS, fuel pump lead.
Any help on which plugs I will not use (since it is a VTEC wiring harness and a non-VTEC motor) or where to plug them in would be greatly appreciated.
samn swap i just did yes there is some wires left , as long as the ls motor wires is all plug up your good
