1995 Civic Cx with a B18A1 swap
95hatchcx
Member
I purchased a B18A1 that came with the tranny, motor mounts, drive axles, and wiring. I know the tranny is a cable tranny and the one in my 95 hatch is hydraulic, also i was wondering about the wiring? i really need help on this, also
if you know any good sites with this exact swap would help also. thanks
you should have researched the conversion better. I also think you are screwed. The tranny is what is screwing you over. I know that they make cable to hydrolic. but most people aren't dumb enough to buy a motor that is older then their car.
Otherwise you will need axels, shift linkage, wiring, ecu... then other little things.
Darin.
I have the wiring, axles, and ecu, motor mounts and all of those goodies.
I thought i could buy a wiring harness adapter?
The B18A uses a cable tranny, you civic with the d16 uses a Hydro tranny. You will need to find a Hydro tranny (off of 94+ Integra, 99-00 Si... or anything that happens to have a Hydro tranny attached to a B series engine) BUT I think Place racing or Hasport may sell a conversion kit.
Kyle
