1995 civic d15z1 idle problem help?
Discussion in 'Civic and del Sol - EG and EK' started by tayninhnn, Jul 15, 2009.
  1. tayninhnn
    tayninhnn Junior Member
    i have 95 civic vx d15z1 motor. drive fine, but sometime it no idle, it will shutoff by itself if i don't give a little gas. this usually happen when it hot. i already changed main rely, clean up the iacv valve. there is no code. thank you
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    How many miles does it have? and have u checked your Fuel filter? may sound crazy but not enough gas and ya your going to shut off :p
  3. tayninhnn
    thank you for reply,the car itself got 177k no i didn't check the filter. it happend when i drove like 14 mile, i can start right back on.
  4. serrilion
    Vermont
    Humm... Well things that make a car go are, an ECU, Spark Plugs, Wires, Dizzy, Fuel, Air lol... and a trany... So my guess would be proably something simple that hasen't been replaced in awhile... Example, Fuel Filter, Spark plugs, PVC valve, proably something small... 177k, Hope the filter was changed recently other wise I dont want to see what comes out of it when it gets changed lol, cause that means it could be gumming up ya fuel injectors too... but ya get it changed its wicked cheap like $13 bucks u could do it ya self, and get a bottle of fuel system cleaner and see how it runs after that
  5. tayninhnn
  6. serrilion
    Vermont
    Could be... if ya got the cash ya could try changing it out
