Alright as the title states I am driving a 1996 Honda Accord EX. I am cheap and realize that I need to replace a bunch of little things and need to pick up some tools so I am trying to do them by priority in a timely manner.
I know a lot of random things about cars but through the power of Youtube I have found that it is easy to learn alot. Eric the Car Guy helps a lot with how to's to fix and search for answers. I have been hearing some clunking and stuff in my car and I have been needing to replace the right CV Axle so I figured I should try and see what all might be wrong and replace a few things or bushings.
Yeah The CV Axel was making some noise and i can see why.
Now the next two things that really caught my eye were the upper and lower ball joints on the right side as well. I mean they had some play and if they broke... wouldn't the wheel fall off? Essentially?
Backside of the upper ball joint, it can dance around a little bit.
Lower ball joint, it too is ripped and can do the shuffle (a little bit)
So i have ordered a right CV Axel, a upper control arm, and a lower ball joint. I was going to try and replace all three. I was like dang, I really only started because I wanted to replace an axel and to get a set of tires. I know some places will not do an alignment with bad suspension parts so I wanted to replace a tie rod.
On the left side the outer tie rod looks fine as far as the bushing/joint. Right where the bend is in the middle of the joint (i guess this is the inner tie rod) is where it is loose. There is a lot of play in the joint. :/
How Difficult would it be to replace this?
Also the right side of the Rack and Pinion is leaking PS fluid. Not very fast but it is leaking and I want to fix this after summer unless it gets too bad. Do I have to buy a new/remanufactured rack or can I purchase a seal kit and rebuild it?
Then later I will replace the sway bar end links and maybe the bushings as well if they are bad.
Yes I know it is very dirty in my car and it looks like I spray under there with oil but I promise you all I don't. There is a leak somewhere... probably the oil pan seal but I'm not really worried about it.
