1997 accord non vtec to vtec f22 swap
Discussion in 'Accord' started by hobojoe2000, Sep 17, 2006.
  1. hobojoe2000
    hobojoe2000 Junior Member
    I have a 1997 honda accord wagon lx automatic currently with vtec f22, I have a low mileage vtec f22 with automatic tranny out of 97 ex I want to swap, not for performance reasons, just cause of high mileage. my question is: Do i have to get a different computer or other wiring or is there and easy way to hook up the ex vtec engine with minimal hassle so i can drive the thing. please let me know anything you can, if this question has already been posted let me know the post or link. thanks http://www.cardomain.com/member_pag...ges/2/web/2414000-2414999/2414935_30_full.jpg
  2. d112crzy
    d112crzy im not a n0ob, trust me
    you will need the computer from the engine you're swapping.
    when it comes to swapping f/h engines in accord/ludes, the only wires needed, depending on application are;
    -vtec solenoid
    -vtec oil pressure switch
    -knock sensor
    only the h22 and h23 require the knock sensor.
    since you are already vtec, you dont have to worry about the first two.
    since the spare engine you have is the same year and is still vtec, then it should swap right in without any problems.
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    I think he mis-typed his post. Look at the thread title - non-VTEC to VTEC F22 swap.
  4. d112crzy
    o, ok.
    then, ignore the parts about not needing to wire anything vtec related.
  5. ITRBOY24
    ITRBOY24 New Member
    chitown
    im having the same problem i have a 96 accord and i i put a obd1 f22 vtech in the car but the car is obd 2 so i ran the vtech wires got a new ecu and now the car boggs down at 3,000 rpm what should i do?
  6. Hondadude141
    TX
    One, it is spelled VTEC not "vtech" and two you might want to start your own thread
  7. EF9_Hatch
    EF9_Hatch Yeah
    Coraopolis, PA
    and not bring one back from 2 years ago
