1997 Honda Civic DX Sedan 4 door.
The car is basically stock.
5 Speed Manual, no grinds.
Shift Knob is from an Acura TL.
Alpine CD player, Pioneer speakers front, Infinity speakers in rear.
Cold A/C, P/S.
OEM floor mats, Drivers side is worn.
Has an OEM Armrest.
Updated Cup Holder. The door of the older style cup holder broke. This is very common if you didn't know.
Has 20% tint all around I believe. The rear window will need to be re-done as its bubbling. It was a professional job so it looks good otherwise. If you aren't old skool then you can remove the tint.
The hood has peeling clear coat. Rock chips and the pressure washer lifted the clear off the paint.
Pics here..
http://www.honda-tech.com/zerothread?id=1347812
Thread on Honda-Tech
It runs good and has the following maintance performed within the last 10k miles.
Exedy OEM Replacement clutch, PP, TO, Pilot Bearing,
OEM Honda Timing belt, Water pump.
OEM Honda Front Brake Pads.
OEM Honda Antifreeze and MTL
Stock Cat-back exhaust
Car is located in Northern NJ but I frequent Albany NY.
$3200
Email me or post a reply, thanks!
Cold A/C, P/S.
Has an OEM Armrest.
Pics here..
$3200
