So i just picked up a bagged dime
1997 chassis, motor, electronics etc
apparently they put a 94 cab on the truck
somehow they seriously ****ed up the wiring
the purple wire that should go to the starter was grounded out on the valve cover and they were trying to run a constant power to the starter to get it to turn over...
now the truck will turn over, but i believe no fuel, no spark, no OBD2 diagnostic communication with the ECU
to turn the truck over you need to have the key in the on position and then connect the 2 wires that I assume should have been for the clutch safety switch
if you turn the key all the way to "START" the motor won't turn over...
any ideas for me? what did these douchebags fry when they had the purple going to the valve cover?
thanks
thanks
