1998 Canadian DX d16 non v-tec to vtec swap
Mitchwolos
Im from canada, my friend has a 98 DX hatch with a JR supercharger
he was doing about 200kms ~120mph and the car just died, i pulled the head off for him, and 2 valves were bent
so i picked up a cdn SI head vtec, i modified the distributor to work from the old head
wired up a rpm activated switch with a 4500rpm
what else should i know??
does this head have smaller combustion chambers?
what model D16 has the thickest headgaskets????
Thanks in advance :)
did you take the piece out of the block to let oil flow to the head for vtec
and also you should consider geting a ecu for a d16y8. you will run lean when you go in vtec and with a sc you will make the problem worse.
couldnt i bump the fuel pressure more?
Also what head gasket do you reccomend for boost
also i didnt see any restrictor in the block?
